O2 Sensor After Cat Waveform
LEGACY7770
Post by LEGACY7770 » Mon Nov 07, 2011 5:37 pm
Can Someone Tell Me What The Waveform Should Look Like For The O2 Sensor After The Cat. My Scanner Shows The Waveform Slowly Moving Up And Down And Is Erratic At Times. The Voltage Stays High
Thanks In Advance Steve
taho
Re: O2 Sensor After Cat Waveform
Post by taho » Mon Nov 07, 2011 11:57 pm
The correct Waveform after the good catalyst very much should change slowly upwards and downwards aspiring to an equal line (in an ideal) 0,45 volt (concerning the sensor earth)
LEGACY7770
Post by LEGACY7770 » Tue Nov 08, 2011 6:03 pm
Thanks Mate!!
Gavra
Post by Gavra » Wed Nov 09, 2011 2:59 pm
When catalyst is good normal waveform is 0.600-0.700 V on idle with very little oscillations. But everything above 0.500V will NOT set up a code . If B1S2 is following B1S1 with oscillation then cat is ready for replacement cause didn't doing job that is supposed to do. Waveform show a rich reading cause Oxygen is used for catalyst process.
Hope it helps ;)
Post by Alan » Wed Nov 09, 2011 4:55 pm
This app note / case study may help
http://www.picoauto.com/tutorials/cat-efficiency.html
