good or bad
ecosse
good or bad
Post by ecosse » Tue Jun 14, 2011 7:08 pm
just took this capture what does anyone think its a 206 crank and and fuel pump :D from an intermitant non start
pug 206 crank and bad fuel pump.psdata
(487.77 KiB) Downloaded 549 times
Re: good or bad
Post by Alan » Tue Jun 14, 2011 7:35 pm
That does look like a fuel pump on its way out. Its always good to have examples of faulty components.
Any chance of capturing over a longer duration say 20ms/div so we can see a repeating pattern on the pump / complete engine cycle?
ecosse
Re: good or bad
Post by ecosse » Wed Jun 15, 2011 1:52 pm
sorry got the pump out and replaced though did notice that when i scoped the pump on the bench it seemed to be ok :D have ordered new pump will post up new capture when fitted
Lee
Re: good or bad
Post by Lee » Thu Jun 16, 2011 6:31 pm
Just out of interest, what is the Exact Vehicle Details i.e.
Peugeot 206
Year......
Engine Type.......
Engine Code.......
I look forward to hearing from you
Re: good or bad
Post by Alan » Thu Jun 16, 2011 6:47 pm
Thanks - please do post a capture with the new pump. Let me explain my request a bit better....
At 20ms/div (or longer) you will have at least one complete engine cycle so everything occurs at least once. Your waveform worries me a little bit as a fuel pump on its way out usually shows drops in current rather than a rise. I wanted to see a longer timebase just to be sure that the peak in current is not related to an injector or ignition coil firing.
I suspect Lee has asked for the exact model for similar reasons - is there any chance that the circuit you measured also supplies other components. This can be a risk when measuring from fuses in particular, it might say its the fuse for the fuel pump but on some cars this can mean fuel pump plus a load of other stuff as well.
ecosse
Re: good or bad
Post by ecosse » Thu Jun 16, 2011 8:51 pm
pug 206
2001 1.6 8v petrol
is the model also think i may have made an error oops since the fuse i think may power something else although i did not have a wiring diag. at the time i did pull the fuse and using live data checked for 02 sensor volts etc and seemed ok and did not log any fault codes also i looked at the capture and the rising bad bit is not in the same place each time which i am bassing on the fact that this part of the trace is not always in the same place based on the missing tooth on the flywheel it did seem random
