Fuel pumps
PeterM
Fuel pumps
Post by PeterM » Wed Apr 27, 2011 7:34 pm
Has anybody noticed that some new fuel pumps [check with your pico] do not rotate at 5-6000rpm [as the book says] - more like 3000rpm [multipoint]. You can check the commutator and the waveform but when you check your new pump, the waveform will be a remarkably different but the revs will be lower. Has anyone else come across this?
Thanks a lot,
Peter.
Re: Fuel pumps
Post by Autonerdz » Wed Apr 27, 2011 8:08 pm
Peter,
Not sure what book you have been reading, but there is no general RPM rule. That varies a LOT as does current level from application to application.
As far as new pumps go though, the waveform is often not well ordered until the brushes wear in.
