pico 4000
km greg
pico 4000
Post by km greg » Wed Mar 10, 2010 7:01 am
i am running pico 4000 automotive on new hp laptop 2.2 g 4g ram in windows seven i have down loaded latest soft ware and installed it when i am running scope in capture after about 2min it stops and reading freezes on the screen.i cant restart program it says not responding in top tool bar i have to force quit and restart.this also happened on old laptop with vista.
Re: pico 4000
Post by Autonerdz » Wed Mar 10, 2010 4:28 pm
There are some issues with the 4000 series driver in the current release 6.3.43.0.
I suggest you go get the 6.3.54.0 beta from Pico Labs and see if that helps first:
http://labs.picotech.com
_________________
http://www.autonerdz.com
skype: autonerdz
In North America
LucaB
Re: pico 4000
Post by LucaB » Fri Mar 12, 2010 10:57 pm
Good evening everyone, same problem happened to me, even with 6.3.54 if required timescales exceeding 200ms/div the picoscoupe does little, and then out.
In particular the defect increases if I use multiple tracks, returning to the previous version 6.2.14, everything is back to normal
Re: pico 4000
Post by Autonerdz » Sat Mar 13, 2010 6:30 pm
Luca,
What are your PC resources? Speed, RAM, type of PC, OS?
Have not encountered this issue with the 6.3.54.0 build.
It sounds like your issue occurs in streaming mode and is worse with more channels. This increases RAM load and PC will fall down without sufficient RAM when samples are maxed in PicoScope.
Not sure why the earlier build worked OK unless the settings used were different.
_________________
skype: autonerdz
In North America
LucaB
Re: pico 4000
Post by LucaB » Sun Mar 14, 2010 8:30 am
Autonerdz Ciao e grazie per la risposta, il PC è un Acer Intel (R) Core (TM) 2Duo CPU, 2,19 GHz, 1,92 GB di RAM, XP Professional Pack3 servizio di sistema.
Come faccio a disattivare streaming?
Re: pico 4000
Post by Autonerdz » Sun Mar 14, 2010 3:25 pm
Sorry, I speak and write only English. I can see you have enough PC there though to run PicoScope unless something else is using it up. Might monitor the performance in Windows task manager and see if the resources are being used up by something.
LucaB
Re: pico 4000
Post by LucaB » Tue Mar 16, 2010 12:48 pm
Hi Autonerdz, I'm sorry but I was wrong.
I used the 6.3.52, I installed the 6.3.54 and everything OK
Sorry again, best regards.
