Test immobiliser antenna coil with Pico?
Dan@KCC
Post by Dan@KCC » Fri Nov 20, 2009 11:01 am
Hey guys,
Does anyone know if you can test an immobiliser antenna coil with Pico?
I think there is a fault with the coil around the ignition barrel and i'd like to know if there's a way to test for a signal.
Cheers
Dan
PeterF
Re: Test immobiliser antenna coil with Pico?
Post by PeterF » Fri Dec 04, 2009 2:20 pm
I have made an adapter for sniffing RF by simply connecting a small RF inductor, about 470uF, across the open end of a 1 metre BNC lead. You can cut the plug off a BNC to BNC lead or wire the inductor to the back of a BNC socket and just connect to the end of an intact BNC to BNC lead.
PeterF.
Dan@KCC
Post by Dan@KCC » Sat Dec 05, 2009 9:37 am
Thank you Peter.
LucaB
Post by LucaB » Sun Jan 10, 2010 11:52 pm
Hello PeterF, I recently purchased the Pico 4423, since I do not understand English well would be possible to have a pattern of transducer that you just mentioned.
