Bosch AFM testing
Bosch AFM testing
Postby Guest » Fri Dec 12, 2008 2:29 pm
Can anybody help me with a testing procedure for the latest air flow sensors as fitted to later vauxhalls Vectra c and astra h. I have come accross 3 cars recently where I have measured a very fast switching square wave pattern on the pin which is normally the output voltage.
Sorry I don't know how to attatch my capture, the frequency of the waveform seems to change with engine load but the duty cycle remains about 50 percent.
Could anybody help me with a testing procedure, should I be measuring current flow?
Any help would be very much appreciated
Thanks John
Guest
Postby chris1234 » Sat Dec 13, 2008 12:20 am
I think you have a Bosch HFM6. The air-mass-information is coded in the frequency and the air-temperature is coded in the duty cycle.
I have an Excel-file for a HFM 6, that you can download here. It's in German, but maybe it's helpfull.
Luftmasse = Air mass
Ansauglufttemperatur = Air temperature
Pulsweite = Duty cycle
Luftvolumen = Air volume
chris1234
Postby Carl Grotti » Sun Dec 14, 2008 12:48 am
Hello John,
Testing "Air Flow Meters" or "Mass Air Flow" sensors can be tricky when they are frequency based instead of a proportional analog one. It can be done fairly easy enough though using PicoScope.
You can do this a few different ways. Utilizing the advanced triggering is one way. Myself, if I were to use a scope to do this, then I would trigger off of the TPS. This would give you a relationship of when the throttle was snapped and the corresponding frequency with the cursors in place.
Another way is to simply use a PGM or a GMM that graphs frequency over time.
Most of the time this can be nailed down with a scanner. Not always though. Out of curiosity sake, what are you using for a scanner?
Carl Grotti
Postby Guest » Mon Dec 15, 2008 9:22 pm
Thanks for your replies. I will have a play with the next one I get in and see how I can best display the frequency.
Carl, I am usind a sykes pickavant ACR 4 scanner. it's very basic and unfortunately cannot graph any of the component data.
Many thanks
John
Guest
Postby Dave Hill » Mon Feb 16, 2009 11:08 pm
Carl Grotti wrote:Another way is to simply use a PGM or a GMM that graphs frequency over time.
I am very interested in developing a useful method of testing these digital MAF sensors. I have to confess Carl that I don't understand the abbreviations that you used in your reply.
Recently I put it to Matt (At Pico) that it would be a cool addition for Pico, if it were possible to graph the frequency over time, in a manner that allowed us to see a plot or simulated signal. This would be very useful for comparing the digital MAF output against the Oxygen sensor, so that effective study of closed loop control can be made.
I don't know if this is a realistic request, but I think it would be a real bonus for Pico.
Cheers
Dave Hill
Dave Hill
Postby Carl Grotti » Tue Feb 17, 2009 8:22 pm
Hi Dave,
Sorry about that.
PGM = Power Graphing Meter
GMM = Graphing Multi Meter
Here is the one I use.
http://buy1.snapon.com/products/diagnos ... ir=catalog
There shouldn't be much trouble finding a used one at a very low price since the V-Pro replaced it.
Carl Grotti
