copy & paste as image Skewed
Postby rvicelli » Wed Mar 14, 2007 3:41 am
Hi, I was trying to copy and paste as image from a saved pattern (which was saved using "save current waveform"). During the paste the pattern was skewed compared to the cursors. In other word the cursors and time frames showed correctly but the pattern was not in the same relationship to them. Attached is an example. Possiblly a problem in my PC but other patterns saved with "save all waveforms as". All were saved a PSD file. This is with R6.06.0. In the attached file only channel D was wrong.
Rob 8)
Sorry cannot attach psd file
If it aint broke...save it
rvicelli
Postby davidj » Mon Mar 19, 2007 11:43 am
Hi Rob
Depending on what you are trying to achieve, the most reliable method of copy and pasting a screen view is using the Prt Scr keyboard button and then pasting into a Word document, for example.
If you register you will be able to attach files.
David
davidj
Postby rvicelli » Wed Mar 21, 2007 3:12 am
I thought I was logged in. Anyway Thats is what I did (PrtScn) after. I just thought it was odd since it was just 1 channel and you might want to know.
Thanks for a great product 8)
rvicelli
