NEW LAPTOP THIS WILL NOT RECOGNIZE SCOPE
MONTY
Post by MONTY » Tue May 23, 2006 10:38 pm
HAVE PURCHASED NEW LAPTOP COMPUTER WHEN I PLUG IN TO PARALLEL PORT IT WILL NOT RECONIZE SCOPE PLUG IT BACK INTO OLD LAPTOP WORKS OK. IFF I GOT USB ADAPTER AND PLUG INTO USB OF WEN LAPTOP WOULD THIS THEN WORK
MONTY
Guest
Re: NEW LAPTOP THIS WILL NOT RECOGNIZE SCOPE
Post by Guest » Tue May 23, 2006 10:42 pm
MONTY wrote:HAVE PURCHASED NEW LAPTOP COMPUTER WHEN I PLUG IN TO PARALLEL PORT IT WILL NOT RECONIZE SCOPE PLUG IT BACK INTO OLD LAPTOP WORKS OK. IFF I GOT USB ADAPTER AND PLUG INTO USB OF NEW LAPTOP WOULD THIS THEN WORK
MONTY
Sarah
Post by Sarah » Wed May 24, 2006 2:06 pm
Hi Monty
You would need to use a Pico USB adaptor, and this would then work. Other adaptors are not compatible.
With regards it not working on the parallel port, I recommend checking the settings in the BIOS of the computer to see what mode the parallel port is set to. Try the other modes available to see if any of them work.
Best Regards
