Oxygen sensor ground connection
what is it
Post by Autonerdz » Tue Dec 05, 2006 4:43 am
Looks like a negatively controlled saturated injector driver with the scaling wrong. Looks like a 20:1 attenuator is attached but PicoScope has not been told that it's there so the 14v circuit shows at .7v.
You will find the 20:1 selection under Settings/Probes. The way it is scaled from 0 to 1v (0 to 20) the injector kick is off the top of the screen. This is normally up to 80 volts. Select the 20:1 and then choose the +- 5v range to scale the screen to +-100 volts (with attenuator in place). Then you will see it all scaled correctly.
RobOnestop
Post by RobOnestop » Tue Dec 05, 2006 8:06 pm
believe it or not its what i got from a lambda sensor
Mobile Mechanic Specialising in
Auto diagnostics & Car Electrics
strange
Post by Autonerdz » Tue Dec 05, 2006 11:26 pm
OK, you had me fooled. That's a classic injector pattern. You even have increasing voltage drop as the current rises. A bit noisy is all.
You need to increase the voltage scale and put some more time on the screen to get a few cycles in view and see the whole pattern. Could be some kind of pulsed O2 heater control. I don't have any info here on your application.
RobOnestop
Post by RobOnestop » Tue Dec 05, 2006 11:31 pm
ive not had pico long so still finding my feet
whats the best setting for zirconia lambdas time base
setup
Post by Autonerdz » Tue Dec 05, 2006 11:44 pm
You need lots of time on the screen to see the O2 cycles. Here is an example series at 1s/div:
http://www.autonerdz.com/cgi/yabb2/YaBB ... 1114921447
These are standard Zirconia sensors pre and post CAT.
