Hall mre crank signal
hbr
Post by hbr »
Is it possible to make a math channel for this mre signal to see the rpm.
With the crank function i don't get a signal and with frequency it is also a mess.
Regards hbr
Mercedes crankshaft mre cil 1 ignition.psdata
(22.72 MiB) Downloaded 83 times
Rfmotors1
Re: Hall mre crank signal
Post by Rfmotors1 »
Hi hbr,
I have attached the file with RPM.
Your capture was good quality and you have recorded long time 1 sec/div which is important in crank signal.
I have saved it with PS7 EA 7.1.15
It is always good to use latest version of the PS7, in case you did not update and used some older version?
Hope it helps
Regards,
Roman
hbr
Post by hbr »
Thank you very much Roman, I can do some tests now.
Regards Hero
