Good morning, I have been asked to look at a 2014 Ford Transit with a 2.2L diesel engine fitted. According to my data source the engine code is USR6. The engine has been recently replaced with a reconditioned unit and cranks but no start. Fault code is P0341- camshaft position sensor A circuit range/performance. Signal compare failure. I have attached a PSD file, it looks as if the camshaft reluctor has no reference signature, just a continual square wave. Surely there should be a fixed position on the camshaft that correlates with the crankshaft wave form signature in order that the PCM can calculate the point of injection. Has anyone please got a known good waveform capture for this engine code?
Hi.
Switching the camshaft sensor signal from high to low level should coincide with the 22 tooth of the crankshaft sensor signal.
In some cases, it can be up to 23 teeth.
