use of existing hardware from Fluke
picofarina
Post by picofarina »
Dear Picotech Team
I am about to buy one of your Kits for the Automotive domain. Allow me a question, please.
I am already owner of a some equipment from Fluke, especially an AC/DC Clamp and an inductive pick-up. How does those equipment suit to your PicoBCN-system, is there any issue?
In other words can I still use these equipment without big interface changes and buy a Starter Kit instead of an Standard Kit?
Thank you for your answer and do not hesitate to contact me in case of further questions.
Best Regards
Kurt
Re: use of existing hardware from Fluke
Hello Kurt, thank you for the post and sorry for the late reply
Our Auto kits are now BNC+ which can be seen in action here https://www.youtube.com/watch?v=QUX6G-anwzg
Now, whilst BNC+ has the advantage of probe recognition, power and zeroing, your existing BNC probes from Fluke (or any other manufacturer) will function with our BNC+ automotive scopes (No interfaces required)
You may have to set up a Custom Probe within PicoScope 7 Automotive software to ensure the correct scaling of any non-Pico probes. You can see this process here viewtopic.php?p=101246#p101246
If any of your probes utilize 4 mm banana connectors, you can add the following adapter https://www.picoauto.com/products/clips ... mm-adapter if required
