New to the PICO NVH. Doing a recording of a "bugged" Audi Q7 drive shaft for class. I am seeing some blue dots with numbers in them on the km/h red line. The programs announces the numbers as they appear. I cannot seem to find this in any material Ive looked at so far. I know its probably something easy that I missed but I give up see attached
Sorry I should have also explained why gear ratios were displayed if you had not populated the Advanced section under the Vehicle information tab
If you load an NVH file (which had been saved with the gear ratio fields populated) and then select "Record and Analyze" & "Start Recording" upon road-test, these gear ratios will be announced as they are saved with the loaded file
