pico diagnostics / pico latest early access using the 2000A BNC+ amp clamp throws alert
tintoverano
Post by tintoverano »
pico diagnostics and pico latest early access v7 using the 2000 BNC+ amp throws the attached alert
the alert is from pd, but pico throws a similar one
in pico the amp clamp can be used after dismissing the alert, but I couldn't accomplish a battery test in pd once the amp clamp is plugged into the scope, the alert cannot be dismissed
submitted this to Support as well already
cheers
Re: pico diagnostics / pico latest early access using the 2000A BNC+ amp clamp throws alert
Hello and thank you for the post (Sorry for the late reply)
I will be in the workshop today and will test this ASAP with 7.0.94 EA
As soon as I have the results I will feedback to you
I could not see a support ticket in the queue, have you received a reply?
I ask because if another support team member has replied, then the ticket will be closed and hence I would not see it
Take care.....Steve
tintoverano
hi Steve,
just tested it last night w/ the latest early release and the issue is gone for both PD and Pico
thanks a lot
zoli
Thanks for the feedback Zoli, much appreciated
Take care.....Steve
