Pico 6 File Won't Save
dannyspro
Post by dannyspro »
Hi All, cannot save file for some reason. Brings up save box but locks up there and I have to restart software. This is on a Windows 7 laptop. Any ideas? Thanks.
Re: Pico 6 File Won't Save
Could you indicate which version of PicoScope 6 software you are using and could you check it is the latest version
You can download the latest version here:
Could I ask, if you leave the PC whilst is is trying to save, will it eventually save?
When trying to save, does PicoScope software remain unresponsive? (You mentioned restart the software, is this via Task Manager?)
Could you confirm you are saving files to your PC, Waveform Library or remote storage such as Dropbox?
Sorry for all the questions but it will help to move things along
Take care.....Steve
dannyspro
Post by dannyspro »
Hi Steve, I actually deleted and reinstalled Pico 6 latest version from the website. I'm trying to save to an empty file on my PC, however the box locks up and doesn't allow me to get that far.
Restart is via Task Manager, entire software locks up.
I'll try to let it sit a while and see if it eventually works.
Hello and thank you for the feedback
Could you confirm your account setting permit saving files from PicoScope 6 Automotive?
I see no reason why not, but if security settings or limitations have been set, this would prevent saving. (It should not however lock your software)
Running as administrator may be another tip that may permit saving and so point to user control settings.
Could you confirm you can save data from Pico Diagnostics (Try relative compression as a rapid test to save)
