gm cop bad spark line
donnyo
Post by donnyo »
on this waveform why is my firing line going negative, this is on a gm truck coil with ballast circuit.
20200207-0001.psdata
(371.84 KiB) Downloaded 319 times
Re: gm cop bad spark line
Nothing to do with the truck, its the scope settings chosen. Select "Automotive" from the menu at the top of the screen and then select the ignition system type you want to test, using the type of equipment you have, and then depress the space bar and test the ignition. If you then compare your settings to the sample ones you should see where mistakes are being made.
donnyo
Post by donnyo »
No I can get good waveforms with the settings I chose, what I found was the car was running non resistor spark plugs. Switched the plug to a resistor type and it cleaned the waveform up.
