Learning the First look waves
DebbieSidera
Post by DebbieSidera »
Hi guys, I have a '53 Jaguar XK120 (straight 6 cyl) at the shop running pretty rough. I thought I was a good opportunity to learn about the First Look tool. Can anyone help to read/interpret these two files for cranking and idling. Also, I would like to know if I counted the cylinders correctly (I delayed 2 cyl).
Best
Debbie
Jaguar_XK120_Exhaust pulse vs ignition at Idle_20190620-0001.psdata
(17.29 MiB) Downloaded 340 times
Jaguar_XK120_Cranking Exhaust pulse_20190620-0001.psdata
(2.21 MiB) Downloaded 342 times
Iver
Re: Learning the First look waves
Post by Iver »
http://senxtech.com/how-it-works/#tab4-works
There you can find lots of information, manuals & videos.
DebbieSidera
Thanks Iver. The videos are pretty much just the theory of the tool. In my opinion there is only one pdf that is really good info. As always, there is a big step from the theory to the everyday world.
Iver
Post by Iver »
Indeed Sidera.
Theory and Real Life don't always agree. I do own a First Look and the results from it are not always easy to analyse when you are new to it.
There, PDF's & Videos will never be as good as actual hands on learning.
My first experience with the First Look made me wonder if it had a place in my life !!
Then I put it on a known good car and created faults. Misfires, Air Leaks ...... ..... .....
That was the moment I went from being confused by the theory to gaining real life, useful hands on experience.
I have also tried the WPS for Exhaust pulse analysis.
They only told me what I could already knew, it's got a misfire !! I could hear and feel by putting my hand on the car that it had a misfire. Of course it would identify the cylinder with some calculations.
Having made the comparisons of both tools I actually prefer using the Crank Sensor with a Math Channel to examine individual cylinder contribution / smooth running. Much easier to read and interpret the results.
The First Look & WPS are great in lots of applications, I'm just not a great lover of them for exhaust pulses.
The other point of note is that here in the UK most cars I look at are 4 cylinder so a misfire is prominent. You can hear it a mile off. With more cylinders 8 or 12 it's not that prominent to the human but the First look will confirm any doubts.
That's my 2 cents.
