Pico software V6.13.14.4038
s4c
Post by s4c »
I have just loaded the latest software version and have noticed that the customer information tab in 'DETAILS' is now missing.
In the past, I have been diligent with logging vehicle reg and customer details and now it appears that is all lost.
Is there a reason for this function being removed?
Simon
Re: Pico software V6.13.14.4038
Post by Alan »
Have you also lost the automotive drop down menu? If so you may have installed the wrong version - make sure you get the automotive version from https://www.picoauto.com/downloads
s4c
Post by s4c »
Thanks for the reply.
I do have the Automotive software loaded.
Simon
Hello s4c,
Thank you for your post and I believe I understand what you are referring too.
The customer details box was removed to fall in line with the 2018 GDPR ruling about retaining and sharing customers information. As we can share PSDATA files with anyone in the world it would fall outside of these rules and therefore we had to remove the box.
Also, please bear in mind that if opening a file with a newer version of PicoScope and then re-saving the file, these details will be permanently removed from the file.
The vehicle details still remains the same and of course there is the notes section where you can add as much information regarding your connection to the vehicle as you like.
I hope this helps in some way and explains why the customer details box is no longer present.
s4c
Post by s4c »
Hi Ben
Many thanks for the explanation.
Simon
