Opel Vectra C Z18XER compression waveform doubt
Post by liviu2004 » Sun Feb 03, 2019 8:22 pm
Hi all,
Did anyone measured the cranking compression waveform for an Z18XER engine?
Got this car with misfire and poor running / idling. I believe injectors clogged, but have a look on the waveform. I've never seen a second pressure dip in the intake stroke.
Any thoughts?
kona
Re: Opel Vectra C Z18XER compression waveform doubt
Post by kona » Sun Feb 03, 2019 10:04 pm
Influence Camshafts Adjusters. (If the accelerator pedal has not been pressed ?)
Try repeat measurement at IDEL.
Post by Technician » Mon Feb 04, 2019 7:14 pm
Not normally any adjustment possible to the valves, they are hydraulic tappets. The compression is low by 4 to 6 bar. The intake depression is not recongised within the trace, pointing towards the inlet valves not opening correctly during the intake stroke.
Post by liviu2004 » Mon Feb 04, 2019 8:08 pm
@kona, it will be no other measurement. I was wondering if anyone else’ve seen this before. Again, that is engine off, cranking, pedal to the metal.
You say that second dip is because of VVT. I tend to believe that, but I am not 100% sure.
Post by liviu2004 » Mon Feb 04, 2019 8:09 pm
@technician, what intake dip with throttle fully open and cranking speed 200rpm?
kona
Post by kona » Mon Feb 04, 2019 8:12 pm
Not normally any adjustment possible to the valves, they are hydraulic tappets. .........
To make you understand :
kona
Post by kona » Mon Feb 04, 2019 8:26 pm
..... I was wondering if anyone else’ve seen this before. .........
Yes. Right. With throttle fully open and cranking.
Post by Technician » Tue Feb 05, 2019 1:33 pm
Sorry for confusion, I was not referring to the VVTi unit(s) when I said not normally adjustable. I was referring to the valve clearances, which are normally hydraulic buckets operating with a zero lash clearance.
seafordmotors
Post by seafordmotors » Mon Feb 11, 2019 7:17 am
This posted compression waveform is correct. Nothing wrong with that, Look at the uploaded waveform f a Z18XER performing OK
Holden Astra AH Z18XER cranking compression No 3 Cylinder OK.psdata
(1.5 MiB) Downloaded 125 times
