Can I daisy chain PicoScope 3423 ?
kier
Post by kier » Thu Nov 17, 2005 10:24 am
We would like to monitor ignition/injection on V8 engines so we need 10 to 12 channel logging simultaneously. Can two or more 3423's be connected via USB hub and feed data into the software as one log ?
Kier.
Daisy Chain
Post by Autonerdz » Thu Nov 17, 2005 5:01 pm
Kier,
While you cannot daisy chain units together with PicoScope, you can accomplish your task another way. Adapters such as the Ferret 953 will allow you to input up to 10 cylinder secondary from a DIS system on one channel. This unit works very well with PicoScope. Then you can deploy a second channel with the low current probe to monitor all the injectors at a feed line. And you still have two more channels ;-)
