2013 Ford transit connect dpf fault.
Frs2180
Post by Frs2180 » Wed Apr 25, 2018 6:50 pm
Evening all. I am currently working on a 13 plate transit connect 1.8 with a blocked dpf due to low temp during regeneration. I have changed a number of the atomizer/ vaporizers across the Ford range due to them failing or blocking. I always carry out checks on my powers and grounds etc before calling a duff vaporizer, today has left me a Little unsure and made me dig a Little more before I replace the component. Using my power probe I have checked unplugged my ground ( all ok) and power to glow plug of vaporizer. Every one I have done so far I have seen battery voltage but this one I am only getting 8.25volts which doesn't seem correct at all. I currently have no data to check it against but I'm sure I should be getting battery voltage. Any help??
Dcunning35
Re: 2013 Ford transit connect dpf fault.
Post by Dcunning35 » Sun Apr 29, 2018 7:52 am
Your quite right the vaporizer glow plug is supplied with battery voltage via the relay , my advice is to bridge pins 3 and 5 at the relay and volt drop the circuit using a 21w bulb to load it in place of the vaporizer.
It shouldn't be to hard to prove your therory of there being a load in the wiring.
Danny
Coburn
Post by Coburn » Wed May 02, 2018 12:02 pm
Did you actually go through with what Danny suggested, Frs2180? I might have the same issue on my car and I'd love to hear your experiences.
