Compression Ford Focus 1.6 TDCI
victor2k
Post by victor2k » Sat Sep 30, 2017 7:25 pm
I have a 2008 Ford Focus with a bad start,white smoke and irregular idle .
At the first check injectors 1,2 and 3 have leaks on return.
Checking the pressure on the return wasn't a step forward...but I lost the recording because of my laptop issue :(
The injectors was checked on a diesel bank and again 1,2 and 3 not passed the test :(
Today I received my new adapter and measuring the compression I see something strange...on some cylinders the compression increase ,on other cylinders the compression decrease...
The engine was cold,injection was disabled,the injectors was removed from engine,all recordings was made in 3-5 minutes.
Any advice is wellcome.
Ford_Focus_2007_Diesel_20170930-0006.psdata
(2.13 MiB) Downloaded 256 times
Ford_Focus_2007_Diesel_20170930-0005.psdata
(746.45 KiB) Downloaded 212 times
Ford_Focus_2007_Diesel_20170930-0002.psdata
(754.48 KiB) Downloaded 203 times
Re: Compression Ford Focus 1.6 TDCI
Post by STC » Sun Oct 01, 2017 12:40 am
If the injector(s) are not sealing at the return ball bearing then compression will be affected. for now it is just an area to explore. I have seen Compression leak in to the Injector return
victor2k
Post by victor2k » Sun Oct 01, 2017 1:07 pm
Today I made some new measurements:WPS body+hose+adapter(measured at 6ml) have 14 ml.
But... Compression test /Pico Diagnostics give me 3 different results at 3 measurements.What I can see in Raw Data is some noise at the battery voltage!All 3 measurements was done with the same setup,one after another!Why the results is different?Maybe some filters will remove the noise from raw data...
Thank you
New folder 3.rar
(281.4 KiB) Downloaded 96 times
Post by STC » Sun Oct 01, 2017 8:39 pm
Stop using that solution.
Use raw data
victor2k
Post by victor2k » Mon Oct 02, 2017 7:06 am
STC wrote:Stop using that solution.
This solution can't be improved?\
Or is more like...don't use this solution if you don't like it? :?
Thank you.
Post by Technician » Mon Oct 02, 2017 8:53 pm
The injector signal(s), where is cylinder 2!
