Compression K9K-702 1.5DCI
Tronic
Post by Tronic » Wed Sep 27, 2017 11:46 am
Hi!
Back after a long period of illness and finally, at least with 50% strength, back att work. We have a 2004 Renault Kangoo with a K9K-702 engine and a non start condition. A relative compression test revealed the following mixed compote: 19, 18, 15 and 20 Bar. My question: what are the compression specifications for this particular engine?
Thanks in advance!
Re: Compression K9K-702 1.5DCI
Post by Technician » Wed Sep 27, 2017 4:16 pm
Hi Tronic,
The technical data I have advises a compression ratio of 18.3.1, this equates to approx 18 bar.
Tronic
Post by Tronic » Wed Sep 27, 2017 8:20 pm
Hi Technician and thanks for reply!
Now I will continue, compression test was just a start. This car have a more or less unknown background, so not much help from there.
Thanks again Technician! :D
volrem
Post by volrem » Fri Sep 29, 2017 5:49 pm
Technician wrote:Hi Tronic,
I disagree. Compression pressure should be higher than compression ratio.
It also depends of additional volume measuring tool has.
With WPS I usually measure measure 22-23 bar (18:1 engine) and with compensation it's 27-29 bar.
post64371.html#p64371
Post by Technician » Fri Sep 29, 2017 5:56 pm
The compression ratio I thought was the minimum acceptable and not the maximum, so yes I agree it should or would be higher when tested dynamically, especially with a warm engine, but as a guide it should be reliable.
Post by Technician » Fri Sep 29, 2017 6:21 pm
I just located a formula which includes specific heat ratio, therefore;
pTDC = 1 bar x 10.3^1.4 = 26.2
The end result I suspect would very much depends on manufacturer cam and valve timing specifications, volumetric efficiency, and what they have calculated as their specific heat ratio.
Mark Dalton
Post by Mark Dalton » Tue Oct 03, 2017 12:34 pm
That looks like a formula from a wikipedia page "https://en.wikipedia.org/wiki/Compression_ratio" where the 10.3 is the compression ratio, so I think your specific formula should be (1 bar * (18.3^1.4)).
Post by Technician » Tue Oct 03, 2017 12:51 pm
Sorry typo error on my behalf
