VW Golf 2005 - PD BKD Engine
Re: VW Golf 2005 - PD BKD Engine
Post by STC » Tue Jul 18, 2017 7:28 am
Do you think it could be caused by someone that messed with the software maps?
That is entirely possible. As I wrote in my initial post, EGR has been Blanked and mapped out. The EGR Diaphragm does not hold vacuum.
For sure the ECU has been out before, missing bolts, connector covers ....
For all I know it could well be the wrong ECU in the car.
Post by KimAndersen » Tue Jul 18, 2017 12:28 pm
Hi STC
I may be able to contribute with some info regarding the scaling of this map sensor - which have the same Bosch part number 038 906 051 C as a VW JETTA TDI 2.0 (BMM) 103kW that I took a picoscope reading of.
I know the engines are not completely identical but the Map sensors are and from this picture below I´ve all the information to make a complete linear curve which later on can be used to interprete the output voltage versus the pressure we are getting.
MAP SENSOR 038 906 051 C
You mentioned that, the specified output voltage from this sensor is between 1.4 to 1.8 volt at idle speed which correspond to 86.38 kPa and 112.67 kPa based of the curve that I made.
MAP SENSOR CURVE #038 906 051 C
When I compare your reading with my readings from the Jetta TDI I´ve got around 100 kPa at idle speed which correspond with 1.6 volt which is right between the tolerance that you described earlyer on - so its not that way off in regard to the specfications !
The pressure reading you got at KOEO is outside the specification and could be someone had been doing some remapping, but it could also be a effect off the changes that are made to the EGR system - I think !.
Kim :wink:
Post by Fat Freddy » Tue Jul 18, 2017 1:05 pm
This throws a Manifold / Boost Pressure Sensor Signal Implausible fault at Ignition on. Won't Clear.
Engine not running I see 1306mB in measured values against 1020 mB atmospheric and desired. The Fault Code is accurate and Validated.
Bosch ESi (this is a Bosch ECU and Component) specifies MAP Voltage to be at 1.4 to 1.8v at Ignition On and at idle - Yes same figures ?? I guess it won't be boosting at idle ?? I have 1.4v with 3 Boost pressure sensors - Original, Customer replacement and Mine from the dealer ( Sealed Package )
But.
Used Sensor Simulator to manipulate values below and above "Desired" ECU reaction is confirmed as Good. Dial it to match atmospheric and the Fault Clears.
And at what voltage was that?
1.4 Volts Confirmed with PP3 and Fluke 123 Scope - and stable, not an average.
Not fluctuating either. Confirmed!
Just to clarify. Is the ECU happy with 1.4V being simulated but not 1.4V when it's from the sensor?
I may be getting confused. :?
Post by STC » Tue Jul 18, 2017 9:40 pm
Freddie
That would be a typo. I am working from memory now. I believe 1.6v is what the sensor output was and 1.4v was what I dialled in to get Measured Values to match atmospheric - circa 1020mB. The correction / drift factor was 200 -250 mV. I did not check to see if that was maintained further up the range or if it compounded.
Kim
Thank you, some good info in your post, I am thinking along the same lines..
There has been progress, I managed to get my hands on a second hand ECU today. With it plugged in the Measured MAP values are spot on :) Using a Mityvac they are accurate across its working range.
Of course the engine wont start - Immobilised, and if it did I expect EGR errors.
Fingers crossed, some mapping and manipulation and I can announce a fix.
I can get a Flash & EEprom reading from the faulty ECU if anyone wants to analyse it to determine if this was a Software or Hardware error - just ask.
dieseljohnny
Post by dieseljohnny » Wed Jul 19, 2017 7:26 pm
Hi STC
Send me on the Flash if you have it handy and Ill have a look at the MAP sensor calibration
Post by STC » Wed Jul 19, 2017 7:29 pm
PM me your email please.
thanks
