PicoScope 6: Spectrum view not visible
anayjoshi
Post by anayjoshi » Wed Jul 12, 2017 8:32 pm
I have been using PicoScope for time-domain waveform capture for over an year now, though I never quite realized PicoScope also had FFT functionality before I bumped across some tutorial videos. The problem is, I am not able to view the "Spectrum view" icon in the toolbar, and neither as one of the views in the "Views -> Add View" section (which lists only "Scope" and "XY"). My laptop screenshot is attached. Anything I am goofing up? I can foresee this could be embarrassing :?
Version number: 6.12.7.2724
Re: PicoScope 6: Spectrum view not visible
Post by Martyn » Wed Jul 12, 2017 9:21 pm
Tools->Properties->Options and enable it there. The button will then appear on the toolbar. It is disabled by default in the automotive software as it is rarely needed.
anayjoshi
Post by anayjoshi » Thu Jul 13, 2017 6:11 am
Thanks Martyn. That worked.
victor2k
Post by victor2k » Thu Jul 13, 2017 8:17 pm
Martyn wrote:Tools->Properties->Options and enable it there. The button will then appear on the toolbar. It is disabled by default in the automotive software as it is rarely needed.
Why at the low freq is only 52-56 dB the noise level with the input shorted to the ground?What OA is used in the input of 4425?
Thank you.
victor2k
Post by victor2k » Sat Dec 23, 2017 2:12 pm
Someone used RG316 coaxial cable for custom BNC to BNC adapter?
If it is used with accelerometers I think is a good solution...
Tronic
Post by Tronic » Mon Dec 25, 2017 4:08 pm
RG316 with single shield is a good choice since it is flexible and withstand heat and rather resistant against petrol and oil. Never thought about using it as probe cable for automotive use though. I mostly use them in RF and with SMA connectors, but BNC with rubber boot will be just perfect. Think I will give it a try and make some lengths.
Hope you all have a wonderful Christmas break
