FL Pressure Sensor
phreniform
FL Pressure Sensor
Post by phreniform » Tue Jun 14, 2005 5:02 pm
Can the FLS connect directly to the inlet manifold (brake servo connection or similar)whilst the engine is running?
FirstLook
Post by Autonerdz » Tue Jun 14, 2005 9:20 pm
Yes. This is how you would set up to see the intake pulses. Now, if you were actually making the connection while the engine was running, you would have to be quick so as not to cause a stall from an open vac leak.
Best to hook up before starting the engine :shock:
phreniform
FL Pressure Sensor
Post by phreniform » Wed Jun 15, 2005 7:13 pm
Thank you for that reply. Has anyone any 212/3 waveforms to show whilst the FL Sensor is connected directly to the inlet manifold with the engine idling?
FLS
Post by Autonerdz » Wed Jun 15, 2005 11:22 pm
Here is one off of a 1997 Dodge Intrepid 3.5 V6 taken at the brake booster nipple. Channel B is an inductive pickup on the #1 plug wire for sync.
Each engine has a different signature.
phreniform
FL Sensor
Post by phreniform » Thu Jun 16, 2005 6:51 pm
Many thanks for the waveform.
