Gas analyzer probe
MD tech
Gas analyzer probe
Post by MD tech » Fri Mar 17, 2017 4:25 am
I ran across a leaking head gasket today, I found it using a liquid co2 tester along with finding air bubbles coming from the cooling system. I was wondering if there are gas analyzer probes available to be used with an oscilloscope that would pick up co2? it would make things a lot simpler, especially if a pressure transducer was used as well.
Re: Gas analyzer probe
Post by STC » Fri Mar 17, 2017 8:08 pm
Holding a Gas Analyser over the expansion bottle will or should give a HC reading with a popped Head Gasket more accurately than the Liquid Test Method, particularly on Diesels - in my experience.
I am no expert on this but I may be able to help until someone with better knowledge comes along.
You could pull your gas analyser apart, locate the sensor or sensors and scope them. If they have some identification on them you may get a data sheet to help you make sense of the output and convert that to actual numbers. Then it is a case of building a "Math Channel" or "Custom Probe"
You have got me started now. I have a Snap on Scan gas and the one thing I don't like about it is that I can only look at one gas level at a time. Would be good to link it up to a scope and see all 4 gasses simultaneously on a scope.
This has been covered on this forum before, here is a link to the thread.
post63521.html?hilit=coolant pressure#p63471
The transducer method I have used many times and it works well. With a second channel for cylinder identification, as long as combustion gasses are leaking into the coolant jacket you will know where the Head Gasket has failed before you lift the Head.
A big help on V engines. Should we be replacing both gaskets if we KNOW that only one has failed ?
MD tech
Post by MD tech » Sat Mar 18, 2017 2:39 pm
thank you, the problem I have is I don't have a gas analyzer right now, and I am trying to find a way to get one without paying the $3-4k that most units sell for. I agree with you that the liquid tester is not very accurate, I don't trust it very much, just use it as a backup to other tests.
Post by STC » Sat Mar 18, 2017 7:39 pm
Used units are available fairly cheap. For example .....
http://www.ebay.co.uk/itm/Sun-DGA-1800- ... 1290007027
http://www.ebay.co.uk/itm/snapon-mot-ga ... 2490102050
