Land Cruiser 3.0TD No Start, Cam/Crank sensor
Liteace
Re: Land Cruiser 3.0TD No Start, Cam/Crank sensor
Post by Liteace » Sat Dec 16, 2017 12:00 am
Tgdevaney wrote:Have you checked that the wires are the correct way around on the crank sensor I know on the subarus it wont go if they are swapped back to front?
Why not read the whole thread?
topic16331.html#p78811
kukushka
Post by kukushka » Wed Jun 13, 2018 6:25 am
I forgot to mention that I solved this issue. It was components in the ECU that had failed. The TCV driver and many others were changed, and the engine runs like a charm.
