Bmw E39 M5. Coil Driver
Post by STC » Thu Jul 07, 2016 9:06 pm
I need some help locating either an exact replacement or a updated part number for this component.
A ignition coil melted and has blown the mosfet.
It is a Motorola component
MG B2
ON36CL
933
Any help, data sheets. Etc. Appreciated. Thanks
andrewbishop66
Re: Bmw E39 M5. Coil Driver
Post by andrewbishop66 » Thu Jul 07, 2016 9:20 pm
try HGTP14N40 just googled the MG B2ON36CL found that they are used in Chrysler and someone had success using this number about $2 each min order 5 from china
Thanks andrew
PicoKev
Post by PicoKev » Fri Jul 08, 2016 9:22 am
Talk to Simon@sparkylabs.co.uk He is a good chap and is a bit of a wizard at identifying and sourcing electronic components. He is very helpful and reasonably priced.
Kev.
Post by STC » Fri Jul 08, 2016 11:36 pm
Andrew, Kev
Thank you both for those pointers, hopefully all I need to produce a fix.
I have emailed Simon and await his response. I like the fact that he is UK based, has a published phone number and, in theory, may be the faster option to obtain the components. Could turn out to be a good man to know.
EAAD
Post by EAAD » Sun Jul 10, 2016 6:50 pm
STC...... Hes the lad who supplies the 'ucurrent' device if you recall?
Post by STC » Sun Jul 10, 2016 10:59 pm
EAAD wrote:STC...... Hes the lad who supplies the 'ucurrent' device if you recall?
Yes indeed I spotted that when I clicked on the link. :D
I shall be talking to him first thing tomorrow and will ask about that device. Thanks for the reminder.
PicoKev
Post by PicoKev » Mon Jul 11, 2016 9:29 pm
STC wrote: I like the fact that he is UK based, has a published phone number and, in theory, may be the faster option to obtain the components. Could turn out to be a good man to know.
You are spot on on all your points, :) there are a number of issues around customs and duties from "down Under" to Europe and the UK, the process can be long winded and expensive. Simon is a good bloke and is sort of a de-facto representative of Dave on this side of the globe. He also sells some really good meter leads if you are in the market for any.
There is :wink: "currently" :wink: a small delay in fulfilment due to a late batch; but get your order in so you can be one of the first to receive your unit.
Kev.
EAAD
Post by EAAD » Wed Jul 13, 2016 4:09 pm
No delay with mine kev..... Kept well informed and delivered in a timely fashion..... Not used it yet but it'll definitely come in handy.
sparkylabs
Post by sparkylabs » Thu Jul 14, 2016 5:12 pm
Evening gents. Thank you for all of the positive feedback. I do my best for people.
Has anybody ever seen a datasheet for this device? At present all I can assume is that it's a MOSFET but I don't know what polarity it is or what its original specifications. I have sought out equivalent MOSFETs before for automotive stuff but I believe that was just a switch for a fuel pump but if this is driving an ignition coil I suspect it's a little bit more delicate.
Searching for the part number does not yield anything and I'm a bit nervous about trusting the datasheet of a part that has mostly the same letters in the part number and maybe a few extra.
Alternatively does anybody have a diagram of the circuit the MOSFET assuming it is a MOSFET goes into?
For anybody wondering about micro currents Dave is currently having the next batch assembled so I am hoping to have them within the next 4 to 6 weeks. I don't think Dave anticipated how popular they would be and he didn't stock up or have them made in huge batches but they have been very well received and I have indeed sold many in Europe mostly to Germany where the rules are so strict as it would seem they only allow stuff in that has a CE certificate if it is from outside of Europe but if it's inside Europe well that's okay no CE certification required apparently.
Post by STC » Mon Aug 15, 2016 8:13 pm
I still have this lurking around.
I did manage to source a component for it, but not fixed it.
I am still convinced that I have a bad component or have damaged it whilst soldering it onto the board. (I used hot air and tried not to cook it too much)
I have scoped the other 7 Good Components in the ECU with the engine idling. The Collector Earth & Gate Signal are Identical in Voltage etc. Only the Emitter to the Coil primary is missing on this one component.
I have good continuity from the emitter to the Coil itself, just as good as the other 7. Also tried switching coils.
I am convinced that my new component is either faulty or damaged.
And that is my question - Is this component faulty ?
