Editing size of saved file
Stevezq
Post by Stevezq » Wed May 25, 2016 3:14 am
Is there any way to edit a saved waveform to reduce its size? As an example I recently save an event while on a test drive and was unable to stop recording quickly. I had a recording of 60 frames, the error occurred across a period of 5 frames. Is there a way to edit a save file so only the desired frames would be saved.
Thanks for any help.
Steve C.
EAAD
Re: Editing size of saved file
Post by EAAD » Wed May 25, 2016 7:22 am
The pico experts on here will guide you with the specifics of 'in house software' editing...... However you can re-record the trace (just the frames you need) on a monitor recorder external software, something like camtasia?
It'll capture the whole screen or just a window like the pico software or even a custom crop....
volrem
Post by volrem » Wed May 25, 2016 9:03 am
I think this image tells all you need to know. Just don't try that with current beta since it just crashes.
Stevezq
Post by Stevezq » Sun May 29, 2016 1:13 am
Thank you for the help.
Steve C.
