ground signal noise
tas_daz
ground signal noise
Post by tas_daz » Sun May 22, 2016 5:50 pm
hi i have a new 4425 pico and i see that i have some noise in signals.i must take good ground from sensors to read,and some videos i see that the older pico not have so much problem.can i do somethink with that?thanks
andrewbishop66
Re: ground signal noise
Post by andrewbishop66 » Sun May 22, 2016 6:52 pm
I found the same thing but used filters to clean up the signals
Andrew
tas_daz
Post by tas_daz » Sun May 22, 2016 7:42 pm
why?the older pico not have that problem.
Post by Alan » Tue May 24, 2016 8:57 pm
PicoScopes (old or new) have shielded electronics internally and the test leads are well shielded.
The wiring loom in a vehicle however is not shielded and wires from sensitive sensor signals run alongside wires from noise generating components such as injectors and ignition.
If you see noise its almost certainly really there in the vehicle - on some sensors you see less noise between chassis ground and sensor out and on others its better to measure between sensor ground and sensor output.
Its unlikely a newer PicoScope is picking up more noise unless because of the extra memory you have it is sampling faster for a given timebase. This could cause it to capture more high frequency noise (which is really there). Given the ECU will have a filter on each input its OK to use either the software or hardware filters to remove such noise.
tas_daz
Post by tas_daz » Thu May 26, 2016 8:49 pm
thanks for help
