Hello, I have a problem when I try to share a waveform which was removed from the waveform library by my own. When I choose "share" on the screen appears message: "This waveform has already been uploaded" and that's it. So maybe someone could help me to solve this issue?
Message:
Error message
I'm sure one of the Pico team will answer, but it might be worth trying to change the file name (using Save As) as well as maybe some text in the details section (not sure how Pico have got duplicate detection setup), otherwise you could post the new wave form here as an attachment or directly to support@picotech.com, and ask them to upload it, and investigate the bug!
Not had this myself, but clearly it's not right, and the ability to amend or update an upload is important.
The feature for users to remove their own waveform is a moderated one. This means one of the Pico team have to actually remove the waveform once it has been flagged for removal by the user.
I have done this for you this morning, so you should now be able to replace it.
Apologies for the delay - I was not in the office on Friday.
