Ford Ranger 4.0 v6 DIS primary current
bonecrusher
Post by bonecrusher » Thu Mar 31, 2016 2:07 pm
Hello
This car hesitates and swithes off. There are no fault codes.
I am working on this v6 Ford Ranger with DIS ignition. I have connected the current clamp to the supply voltage for the coil. This is the pattern I have. I cannot make any sense of it Why does it have 2x (signal?) at times.
volrem
Re: Ford Ranger 4.0 v6 DIS primary current
Post by volrem » Thu Mar 31, 2016 2:37 pm
bonecrusher
Post by bonecrusher » Thu Mar 31, 2016 3:19 pm
Thanks,
It all makes sense!
Understand perfectly now!
bonecrusher
Post by bonecrusher » Sat Apr 02, 2016 8:11 am
Hello Guys
Found the fault on this car. The crank sensor was at fault. It was adjusted too close too the pickup wheel, all I did was take it a few millimeters back and the car revs up. This makes absolutely no sense to me. I have attached pics of the CKP at idle. The pic with the higher amplitude is when the Car idles but does not rev/switches of as soon as the throttle is depressed.
1st pic everything works as is
2nd pic is when problem occurs
All waveforms taken at idle
Post by Fat Freddy » Sat Apr 02, 2016 8:59 am
Looks like a damaged tone wheel to me. :shock:
Some one been sticking things where they shouldn't? What's history?
HTH
Post by STC » Sat Apr 02, 2016 8:12 pm
Psdata file with the sensor in its original (faltering) position from start up to cut out, with pedal position if easy enough to get would have been interesting to look at.
