Feature Request - WaveForm Library
Post by STC » Sat Mar 26, 2016 7:52 pm
I am working on a problem vehicle (Poor Idling) at the moment and have several waveform captures utilising 2x First Look Sensors (inlet & exhaust) Amp Clamps on Starter & Injector Current then CKP, CMP, FRP, MAF .....
I can upload these to the Library as we speak making it clear that they are either Unknown or Bad, that being the Issue, Until I fix it I have no clue and nor will the other users.
Once the vehicle is fixed I intend to take the same captures again.
The request being that I would like to post the captures as a Pair (Before and After). Perhaps be able to create a Folder / Link within the Library and explain what the fault / cure was. Add Pictures too.
It is something that I would like to have access to.
Known Good Captures have a value - Priceless! Whereas bad captures don't rank so well until you put them along side the cure and then the good from the same project ?
Just as we see in the PICO Case Studies.
volrem
Re: Feature Request - WaveForm Library
Post by volrem » Sun Mar 27, 2016 6:37 pm
Not exactly what you asked but you can always log in to waveform library and edit uploaded waveform notes and other information even months later.
