Saving a Waveform at Vehicle Details ... lost waveform
FioranoCars
Post by FioranoCars »
I was showing a trainee how to save a file, with all the vehicle details being completed and managed to lose the waveform, while the save dialogue was still open!! I had a drop down open (I think it was selecting Channel B's item - ie "Battery voltage") and possible pressed a keyboard combo - [end] or [ctr+end], really not sure ... but a file loaded in the background and replaced my waveform! It loaded a file from the same directory that my starting template file had been loaded from, but it was not a recent file.
I finished the full save, just in case my data was still there, in the background somewhere, but it was not!
This is clearly a bug, you should not be able to load a new file while saving! (cable and scope where not unplugged, but this has happened during saving, another really annoying issue).
Also, the [enter] key takes you to the filename dialogue, with no way back to the vehicle page, please can you change the [enter] key to select the data - if in a drop down - and provide a path back to vehicle page, from the save filename dialogue. People love [enter] and use it to select, maybe use [ctr+enter] to move to the filename screen?
Richard Lukins
FioranoCars.com
Re: Saving a Waveform at Vehicle Details ... lost waveform
Hello Richard and thank you for the post and feedback.
I have not been able to reproduce the symptom of inadvertently loading a waveform in the background and replacing the waveform you are saving.
I have followed the combination of keys you selected (End and Ctrl/END) but the waveform remains stable with none loaded
Not sure if you may have these keys assigned to a specific shortcut under the Preferences/Keyboard menu?
It may be worth checking as my keyboard map is set to default.
I can see how the Enter key may introduce confusion when entering vehicle details as this takes you straight to the File Name dialogue box as you mentioned.
I will add this as a new feature request as a customisation feature for the software team.
Take care.......Steve
FioranoCars
Hi Steve
Sadly can't remember the exact combo of keys, and new trainee was driving the keyboard, so could be anything, even 3 or 4 keys at once or even an ! but I would like to think that within the software code it might be easier to track this bug ... and no I've been unable to reproduce it, buy I was watching as it happened and swore several times :-)
Also can you add to the list of test conditions "KeyOn EngineRunning WheelsTurning" ? For ABS and Road Speed issues this has some improved clarification ?
Where is the vehicle database stored on Win7 machines?
Richard Lukins
FioranoCars.com
