volts to pressure
ecosse
volts to pressure
Post by ecosse » Mon Jan 04, 2016 10:06 pm
Hi guys I'm looking to convert a voltage signal from a bosch FRP sensor into a scale for reading pressure.
Also I'm only looking at reading up to 400bar with this sensor so only over 2v needed on the scale.
could anyone remind me how to set this up? I should know but its been a while since i messed with the software!
Kenny
Re: volts to pressure
Post by Steve Smith » Tue Jan 05, 2016 11:13 am
Hello Kenny and thank you for the post.
You will need to create a Custom Probe to enable the software to convert the voltage output of your pressure sensor into a pressure unit of your choice.
There are a couple of posts you may find of interest here at
post36911.html?hilit=fuel%20rail%20pressure#p36911
topic9899-10.html?hilit=denso
To create a Custom probe within PicoScope select Tools > Custom Probes > New probe > and follow Custom Probe Wizard.
As you move through the Wizard you arrive at the Scaling Method where you can use a Look-Up Table to input the voltage output of your sensor relative to the pressure applied
Continue through the set up Wizard until complete where your new Custom Probe will appear for selection in the Library section of your probe menu under your Channel options. (Probe selection)
I hope this helps but please feedback if you need any further help
Take care......Steve
Post by Robski » Tue Jan 05, 2016 4:05 pm
ecosse wrote:Hi guys I'm looking to convert a voltage signal from a bosch FRP sensor into a scale for reading pressure.
Kenny
If your inbox was empty I'd have replied ....................
ecosse
Post by ecosse » Tue Jan 05, 2016 8:06 pm
inbox here rob? or on the dark side? :D
ecosse
Post by ecosse » Tue Jan 05, 2016 8:30 pm
Thanks for the tips Steve :D
I will let you know how it goes
Kenny
