Maths Channel
s4c
Maths Channel
Post by s4c » Sun May 10, 2015 8:00 am
Can someone help with a maths formular to make a maths channel for fuel pressure.
I would like to make one to trace the high pressure rail voltage and turn it into pressure on a common rail diesel.
Simon
Re: Maths Channel
Post by Robski » Sun May 10, 2015 10:27 am
s4c wrote:Hi
Simon
So how is one to do that without the pressure sensor data or even system ( and would more likely be a custom probe) ??
s4c
Re: Maths Channel
Post by s4c » Sun May 10, 2015 7:52 pm
Hi Robski
You could be right. I will play with the probes.
I was thinking that if you know that say 0.5 Volts is 0 bar and 4.5 Volts is 1600 bar there must be a maths channel/Custom probe to calculate this.
Any help would be be great
Simon
Re: Maths Channel
Post by Steve Smith » Mon May 11, 2015 11:31 am
Hello and thanks for the posts.
I think the custom probe setting would be the way to go as Robski mentioned.
Could you take a look here at http://www.picoauto.com/support/topic98 ... 20pressure
Here you will find a custom probe produced for a Denso system and a great discussion surrounding the technique.
Can you let us know how you got on?
Take care.....Steve
