Adding Rulers in Capture ?
terbo
Post by terbo » Tue Jan 27, 2015 8:27 pm
Version i the 6.10.11.15
I have a Capture i took, then i bring up 2 Rulers from the bottom
left side. O.K - now there are to rulers on the Screen.
I now would like to add 4 egual spaced rulers between these to rulers.
So i go to rulers, set it to 4, and nothing happens.
What am i doing wrong ?? How do i get this to work ?
Chris
A_phoenix
Re: Adding Rulers in Capture ?
Post by A_phoenix » Tue Jan 27, 2015 9:09 pm
Hi Chris,
I believe you have simply grabbed the wrong set of rulers. On the bottom right side of the screen is a blue/green dot, drag those out to your capture. Now you should be able to use the rotation partitions.
Cheers,
Andrew
Post by Robski » Wed Jan 28, 2015 8:38 am
I thought only 2X time rulers were available, if you use the rotation rulers then you can have 4X.
terbo
Post by terbo » Wed Jan 28, 2015 12:38 pm
Thank you....
It can be so easy...As most times - Error 30 - 30cm away from Keyboard ;)
With the rulers from the right side it works just as i wanted :)
Greets Chris
PicoMike
Post by PicoMike » Thu Jan 29, 2015 8:48 am
Great example of the forum support here!
Thanks guys,
Mike Valentine
