03 1.4 lt Petrol Ford Focus No start
careys
Post by careys » Wed Jan 14, 2015 11:06 am
Wetting plugs , no fault codes logged
Pico reads 45 ms injector pulse on cranking ? what should I expect on cranking ?
when engine did fire intermittently with aid of starter, inj pulse read 18 ms as engine died out
Map sensor, tps , temp, all seem normal
I wonder has anybody seen a similar problem, or any suggestions ?
careys
PicoMike
Re: 03 1.4 lt Petrol Ford Focus No start
Post by PicoMike » Wed Jan 14, 2015 12:17 pm
careys wrote:Wetting plugs , no fault codes logged
careys
Hi Carey,
Have you checked our Waveform Library? I found a trace relating to a 2004 Ford Focus, Injector Current and Voltage (taken when the engine was idling).
To find this waveform in the library:
Open the waveform library browser, and choose
Ford
Focus
Engine code: FFDA
This should show you two results. One of which is injector voltage and current.
Hopefully this will help, in the meantime perhaps others will be able to contribute here.
Mike Valentine
