non pico pressure transducers
LucaB
Re: non pico pressure transducers
Post by LucaB » Sun Jan 18, 2015 12:53 pm
leemack wrote:I don't know much about in cylinder pressure checks but doesn't the wps500 also measure negative pressure during a running compression test.
Hi, You are right by the rush I had not thought.
Try this probe
I repeat only work if the data entered on the relationship tension / pressure are correct and if the sensor is linear.
Robski wrote:How would that go on with in cylinder pressure ?
I do not understand question, my English is bad.
Apply otherwise
Best regards
Transducer Snapon by -30 to 500PSI.psprobe
(2.25 KiB) Downloaded 296 times
LucaB
Post by LucaB » Sun Jan 18, 2015 1:05 pm
Hi, I forgot, if the sensor signal is not linear but logarithmic put voltage values for the different presses that then try to do probe.
Best regards
Post by Robski » Sun Jan 18, 2015 1:28 pm
LucaB wrote:Hi, I forgot, if the sensor signal is not linear but logarithmic put voltage values for the different presses that then try to do probe.
Best regards
my 1/2 Italian is bad.Apply otherwise ??
Rush ????
The probe you created never went negative !
leemack
Post by leemack » Sun Jan 18, 2015 8:26 pm
I configured a probe from the results of a pressure/voltage test but sith the engine running the zero voltage drops negative so the zero psi isn't correct from the start.
Without the engine running the 0psi scsle of 0.5v = 0 psi is correct. I've now got the use of a wps500 instead but it would've been nice to get it working.
Post by Autonerdz » Sun Jan 18, 2015 9:14 pm
leemack wrote:I configured a probe from the results of a pressure/voltage test but sith the engine running the zero voltage drops negative so the zero psi isn't correct from the start.
You have now proven to yourself the problem with most transducers out there. You cannot make a custom probe for a transducer that is inaccurate. They work OK in a static measurement application but are wildly inaccurate under dynamic conditions such a running compression test.
As far as I know, there are only three transducer choices that don't have this problem. The Pico WPS, the Fluke PV350, and the DCTI. We did extensive testing here on dozens of transducer candidates for the developer of the DCTI and found them all problematic. He ended up having one custom engineered. Of these choices, the WPS is the most versatile.
The ONLY PicoScope automotive specialists in North America
leemack
Post by leemack » Mon Jan 19, 2015 9:22 pm
Tom Roberts,
thanks for that as I thought I was going mad, so it appears it wasn't really made for the specific task I was attempting to carryout. Even with the snapon scope it proved inaccurate.
Post by Autonerdz » Mon Jan 19, 2015 10:11 pm
leemack wrote: thought I was going mad,
I am familiar with that feeling. :roll:
You are welcome.
Tom
madhuridixit
Post by madhuridixit » Wed May 27, 2015 1:36 pm
Am using PICO WPS500X Automotive Pressure Transducer (PP652) but the drop of voltage is very huge. How to rectify my issue???
