Emissions problem BMW M3
trutrail
Post by trutrail » Sun Jun 15, 2014 7:27 am
We have an issue with a BMW M3 1996 3ltr. The co reading is off the meter (literally) but the odd thing is both O2 sensors work perfectly normal???!!! They oscillate at about 2hz when warm and range between .1 and .9 volts. Any ideas? We were thinking it could be that it is burning oil as the HC reading around 1100ppm. But appart from that I have never seen anything like this.
HC_CDC
Re: Emissions problem BMW M3
Post by HC_CDC » Mon Jun 16, 2014 1:21 pm
I don't know if it the intention of this forum but that will be told by some administrator. Obviously you need an answer quIckly and if you haven't solved the problem yet; you may want to look at a false lean situation, leak in exhaust system upstream or near lambda sensors 1.1 and/or 2.1.. ECU will be enriching because lambda sensor tells it the mixture is lean.
Good luck
Henk
Post by Robski » Mon Jun 16, 2014 8:53 pm
Any body :?:
What's the cross count ?
Misfiring ?
Are any fuel trim values available to you ?
trutrail
Post by trutrail » Fri Jun 20, 2014 5:47 am
Thanks for the replies so far. Much appreciated. This car did have a missfire (But if you've ever worked on one you'll know the fault codes and live data for this system are very basic indeed. It did not even recognize a missfire at all!) Thanks god for oscilloscopes we nailed it in 30 seconds and rectified that fault. We will bring it back in and look for an air leak in the exhaust system upstream of the o2 sensors. Cheers so far.
