Pico Diagnostics Default Settings
Ed P
Post by Ed P » Fri Apr 18, 2014 2:31 am
Is there a way to permanently change the default settings? I've changed them through the preferences tab but they reset upon restarting the program.
Thanks!
Ed
Re: Pico Diagnostics Default Settings
Post by Steve Smith » Fri Apr 25, 2014 2:21 pm
Hi Ed and thanks for the enquiry, sorry for my late reply. Can you let me know which test you are using in Pico Diagnostics or are you using PicoScope. The start up settings for PicoScope are found under the FILE menu and START UP SETTINGS if so.
Can you feedback when you can? Take care.....Steve
Ed P
Post by Ed P » Sat Apr 26, 2014 12:57 pm
Hello Steve,
I'm running the test through the Pico Diagnostics program. I see the settings you speak of in Pico Scope but not Pico Diagnostics.
Thanks,
Ed
Post by Steve Smith » Fri May 09, 2014 1:50 pm
Hello Ed, sorry for the late reply. I have just checked the latest version and you are right as it does not retain the pressure value or the measurement system. I will file a report and send this into the software team. This should therefore be resolved on the next build. Once again, thank you for pointing this out.
All the best.....Steve
