Links to useful information
- Pico Staff Member
Rather than copying this out, you can find Steve's original post here - viewtopic.php?p=57531#p57531
I know some of it this isn't relevant to the types of machinery likely to be seen but a lot of the techniques and measurements can be carried over.
For quick access I've listed below the case studies which show Pico in action for the HD and Off Highway sector.
Case Studies-HGV-Commercial-Agricultural-Heavy Machinery
https://www.picoauto.com/library/case-s ... f-warnings
https://www.picoauto.com/library/case-s ... -australia
https://www.picoauto.com/library/case-s ... blue-fault
https://www.picoauto.com/library/case-s ... munication
https://www.picoauto.com/library/case-s ... under-load
https://www.picoauto.com/library/case-s ... sure-fault
https://www.picoauto.com/library/case-s ... ging-power
https://www.picoauto.com/library/case-s ... k-of-power
https://www.picoauto.com/library/case-s ... ring-fault
https://www.picoauto.com/library/case-s ... no-restart
https://www.picoauto.com/library/case-s ... cu-failure
https://www.picoauto.com/library/case-s ... eter-drift
https://www.picoauto.com/library/case-s ... om-misfire
https://www.picoauto.com/library/case-s ... ve-failure
https://www.picoauto.com/library/case-s ... e-shutdown
https://www.picoauto.com/library/case-s ... ault-codes
https://www.picoauto.com/library/case-s ... idge-cable
https://www.picoauto.com/library/case-s ... slow-winch
https://www.picoauto.com/library/case-s ... nch-part-2
https://www.picoauto.com/library/case-studies/misfire
viewtopic.php?p=100812#p100812
Hope this helps.
Re: Links to useful information
- Pico Staff Member
Hopefully it will help you find what you're looking for. If you can't find something though, do feel free to post a question on the forum. We're all here to help and support one another.
