Anyone having a cam crank correlation waveform for Opel / Vauxhall Zafira B 2.2 Z22YH?
Cam is hall, crank is inductive. Not the same as 2.2 Vectra C waveform.
Have this car here with suspected jumped timing chain. Max cylinder pressure 5.8 bar, intake event at - 0.8 bar, big vacuum pocket by expansion phase.
Thanks, it helps, I can see the exhaust being 1 teeth difference, but I suspect intake cam to be way off, judging by the cylinder compression waveform.
