1989 Mercedes 560SEC Ignition Wiring Diagram
Iver
Post by Iver »
I have no spark, Crank Sensor is good but I need to check Power Supplies & Inputs.
I need a wiring diagram for the Ignition Module on this car. It is what the call the "High Output" Model with Knock Sensors.
There is a diagram on "Tolerance" which is for the low output Model. I have Mercedes STAR & WIS. The diagram is not there.
I'm guessing it will be in a Paper Manual or Microfiche someplace and never got digitised.
Can anyone help ?
This is the Module
speck
Re: 1989 Mercedes 560SEC Ignition Wiring Diagram
Post by speck »
Hi, this diagram is for a 1989 300sl, your ignition module looks exactly the same. Maybe this diagram can help you. I'm not sure.Kind regards
Iver
Post by Iver »
Thanks for the info guys.
A new Ignition Module fixed this.
