Hi Michael,
I was just wondering whether a suggested "structure" for feedback would elicit more responses. Maybe separate threads for specific features that you'd like to see, etc.
My intial thought is that R6 looks much more like a "designed" product than R5 -- with its decidely "glued-on accessory look" -- ever could be. That should mean a much faster learning time.
Responses for bugs are probably not a problem, but being constructive about a bug is quite tricky .
I have data for a bug in Save As... image formats.
Also what do you need? I assume you will always want the PSDATA file? The fault can be seen in buffer 19.
Attached ZIP containing: PSDATA, PDF showing Print output, GIF showing screen shot, PNG showing Save As.
Best regards,
Ed
Oops it refused that because I used 7z instead of Zip.
Try again.
Oops2. It will accept ZIP, but it's too big. Actually it's way too big. I'll rename the zip file to a vi file (whatever that is) to slip under the radar.
[The extension vi has been deactivated and can no longer be displayed.]
A structure would be good but we are not yet there with a finite list. I guess we are mainly after a feedback overview and any strange bugs that crash the software for any unknown reasons. Where we have identified a particular bug, we will post an announcement. This should help those of you that have found a problem and are unsure if it has been found already.
Good luck with testsing and let us know your opinions.
Best regards,
Michael
Michael - Tech Support
Pico Technology
Web Support Forum
...I guess we are mainly after a feedback overview and any strange bugs that crash the software for any unknown reasons. Good luck with testsing and let us know your opinions.
Best regards,
Michael
Michael, I assume you're aware that Tablet PC will crash repeatedly on version 6? And it doesn't just crash, it wipes out all of the restore points. I bought a Gateway tablet specifically to use under the hood. It would be nice if this bug were worked out - soon. Yes, I can use version 5, but 6 is so much more intuitive and easy to use.
CM
