Does anyone have a recommendation for a pass thru device for the NVH to read RPM Speed etc? I originally was able to use my Escan pro, but that has stopped, I tried my Bosch VCI, Flasher pro and my OTC MVCI with nothing working. Any ideas?
Assuming the devices you mentioned are Pass Thru devices (via the J2534 Protocol) they should function with our NVH software.They will however require the relevant Driver to function as a Pass Thru device
I know with a number of Bosch users with Pass Thru devices a firmware update was required accompanied with a "Check Box" requirement to "Enable Pass Thru" within the relevant software. This would also be Hardware specific and I refer to the KTS 590
Thanks Steve, I purchased the Mongoose and still cannot connect too 2 vehicles, a 03 7.3 diesel Excursion and a 99 lincoln town car, but it seems to connect to newer vehicles quickly. Any ideas?
automotivemd wrote:Thanks Steve, I purchased the Mongoose and still cannot connect too 2 vehicles, a 03 7.3 diesel Excursion and a 99 lincoln town car, but it seems to connect to newer vehicles quickly. Any ideas?
On diesel cars from 1996 to 2003 OBD II not offer a complete coverage,also your purchased Mongoose ISO/CAN 2 can support only ISO,KWP and CAN protocols ,not J1850 VPW and PWM protocols(for this you will need Ford or JLR Mongoose) .
I think a ELM327 clone or a Bosch KTS with passthru firmware will work better.
Best regards
