Volvo v70 diesel
mekaniker
Volvo v70 diesel
Post by mekaniker »
Hello, need help/advice
2008 Volvo d5 idle fine, good power, start fine, no faultcodes, injector return looks ok, but dont run fine driving 50-55 km/t, have som missfire/shaking.
New oil and filters, also used /bg-245-diesel-premium-fuel-system-cleaner.
Ant idea?n
RYM6746
Re: Volvo v70 diesel
Post by RYM6746 »
What is the fuel pressure doing whilst the fault is occurring?
mekaniker
Post by mekaniker »
RYM6746 wrote:What is the fuel pressure doing whilst the fault is occurring?
Around 500 bar , 1550rpm
Any chance you have a scanner capable of recording live data?
Take it for a road test at the said speed and then play back the live data and see what circuits are affected ?
mekaniker
Post by mekaniker »
Technician wrote:Any chance you have a scanner capable of recording live data?
Yes, i Will try to record some data....
volrem
Post by volrem »
Scope crank sensor and sync it to some injector current. And post here.
RYM6746
Post by RYM6746 »
If possible scope rail pressure over a long period of time with a high sample rate whilst the fault is occurring. I am guessing it will be fluctuating which will indicate a IMV issue. I have seen this fault before on volvos. See if it has 2 regulators on the pump. If it does fluctuate and does have 2 regulators it is usually the regulator under the pump which is difficult to see. I am pretty sure you can only buy that perticular regulator with the pump
I have before and after waveforms. If this is the fault I think it is. Post the waveforms on here so I can take a look
volrem
Post by volrem »
RYM6746 i bealieve you are taking about 2.0D engine. This is 2,4 and does have two regulators but volume regulator is on pump and pressure regulator at fuel rail.
This of course doesn't mean that there could not be something wrong with either of these.
RYM6746
Post by RYM6746 »
Ahhh yes you are correct that was the 2 litre.
Definitely worth a shot on scoping the fuel pressure whilst fault is occurring.
At the very least, you can at tick it off the list of possibilities
