Compression Ford Focus 1.6 TDCI
I have a 2008 Ford Focus with a bad start,white smoke and irregular idle .
At the first check injectors 1,2 and 3 have leaks on return.
Checking the pressure on the return wasn't a step forward...but I lost the recording because of my laptop issue :(
The injectors was checked on a diesel bank and again 1,2 and 3 not passed the test :(
Today I received my new adapter and measuring the compression I see something strange...on some cylinders the compression increase ,on other cylinders the compression decrease...
The engine was cold,injection was disabled,the injectors was removed from engine,all recordings was made in 3-5 minutes.
Any advice is wellcome.
Ford_Focus_2007_Diesel_20170930-0006.psdata
(2.13 MiB) Downloaded 794 times
Ford_Focus_2007_Diesel_20170930-0005.psdata
(746.45 KiB) Downloaded 688 times
Ford_Focus_2007_Diesel_20170930-0002.psdata
(754.48 KiB) Downloaded 647 times
Re: Compression Ford Focus 1.6 TDCI
If the injector(s) are not sealing at the return ball bearing then compression will be affected. for now it is just an area to explore. I have seen Compression leak in to the Injector return
Today I made some new measurements:WPS body+hose+adapter(measured at 6ml) have 14 ml.
But... Compression test /Pico Diagnostics give me 3 different results at 3 measurements.What I can see in Raw Data is some noise at the battery voltage!All 3 measurements was done with the same setup,one after another!Why the results is different?Maybe some filters will remove the noise from raw data...
Thank you
New folder 3.rar
(281.4 KiB) Downloaded 493 times
Stop using that solution.
Use raw data
STC wrote:Stop using that solution.
This solution can't be improved?\
Or is more like...don't use this solution if you don't like it? :?
Thank you.
The injector signal(s), where is cylinder 2!
