What is causing the low frequency vibrations?
LarsT
Post by LarsT »
Hi, I am still learning how to use my new NVH kit sorry if this is too simple of a question. The customer is complaining of a steering wheel vibration, I recently replaced the tires - two of them had high roadforce readings, however the customer is still complaining of a vibration. I noticed a low frequency that is high but not labled. I thought is might be caused by the road but just curious if anyone could give me and answer.
Thanks Lars
pico,Desart, route 24 east.pddata
(699.8 KiB) Downloaded 628 times
LarsT
Re: What is causing the low frequency vibrations?
Post by LarsT »
I have read that the lower frequencies are caused by the cars mass and its suspension system.
tode
Post by tode »
The frequency you see is very low 1,4 HZ , it means 1,4 fluctuations at second for me isn' t possibile the cause are tyres o transmission because their frequency is much more high than 1,4 hz.
If the vibration that you feel is 1,4Hz (1,5 at second), i think the problem come from powersteering .
Martinjensen
Post by Martinjensen »
Hi Lars.
I have previously asked that question.
See this thread: topic15921.html Question 3, and the reply from Pico's NVH expert Steve Smith.
Hope this helps.
Regards Martin
LarsT
Post by LarsT »
Thanks Martin, I thought I had seen it but it was not coming up in my searches.
Lars
